O.K. Im not a welder, but I have done some arch welding (thick metal) in the past and tons of reading on mig welding already and some practice with the mig of course. I like to do things my self when possible and I am also a very fast learner. But Im welding a body panel on my mustang right now, and Im afraid it will crack when its all painted and done. Also, do I spot weld the hole thing little by little? I can't run a bead it burns a whole right away! How do I know the welds will hold and not crack later. they are pretty thin once I grind them down and some do crack. Sometimes when I make a mistake on panel aligment or something and try to undo the spot welds, they are pretty hard and tight to remove which is good right? Is it just me or is this the way its done I have a very cheap mig welder, no gas. I use it on the lowest setting with 30 wire. Any help will be greatly appriciated thanks, Abel
