Yes. I think the hardest part is the intimidation factor. I mean, when you start cutting out those factory towers, you're committed. And then, when you weld in that crossmember, it better be absolutely, positively centered. After that, it's basically bolt on kind of work. I would also mention that after one does this, take it to a good front end alignment guy who really knows what he's doing. The first place I took it to aligned it stock '61 Falcon specs! Idiots! Even then it drove a hell of a lot better, but then later I brought it to another guy who discovered the previous problem and did it right, and the little car really handles well. Especially with the dropped spindles.
I've heard that a Shelbyfied front end with the lowered A-arms and all that can easily outperform our front ends which is probably true. Still, that's a lot of work and expense, and probably takes a great deal more futzing with it to get it right on our cars. Oh. And you still have those darn shock towers!
