1 - 8 of 8 Posts
I currently have my 66 coupe at the restoration shop where it is, at this time, being media blasted. I have full intentions of performing a mini tub and leaf relocation to get a pair of 315/45/17 tires under the car. I have spent endless hours researching message boards and talking to people to get some guidance/advisement to performing this task. Is there anyone who has been through and done this to a coupe. If so, I would really like to see some pictures. Thank you in advance!
I did this to my 66 fastback, same wheel well as coupe. Relocating the spring mount to the inside of the frame does not gain you a whole lot of room because the rear frame horn curves into the wheel well as it goes rearward.
I used competition engineering bolt in sub frame connectors that were bolted into place to hold them and then fully, and I mean fully, welded. The new front mount is then anchored to the insidse of the original frame mount and to the new sub frame connector with a little new metal added. For the rear, weld some angel and a piece of roll bar to form a new upper mount off of the original frame.
I need to take pictures...
yes please post some pics, im in the same boat. BTW what size tires can you fit under there?
I'm sort of curious about this too. I'm going with a custom 4 link setup, so the springs will never be an issue lol, but I'm curious what size tires will fit under 65-66 sheetmetal without flares.
Cris
IsBadFord: The 26x8.5 MT slicks will fit great and stick pretty good up to 450-500HP to the ground. The slick I run is a 28X9, which took a little fender rolling and I had to move the rearend back about 1/4" so they would not hit the front rocker panel at high speed. Also it is important to have a good suspension that does not squat, or you will hit the top of the tire. I know there is one other guy runnin ghat size tire, because he told me it worked for him. All cars are a little different so you would just have to give it a try. I do know that a 10" slick is not going to fit.
Is that with a spring relocate and mini tub, or without? If without, that's a good sign I'll be able to get a LOT of tire under my car =). If with...there still may be some small things I can do to get a 10" tire under there. The 4 link I'm using is the same as a late model stock car. Bird cages on the axle housings with a panhard bar to locate the rear and let it roll. The locating arms are simply 3/4" steel tubing with rod ends. Not much impact on clearance there, particularly since they're located well inboard of the frame rails. I suppose the major issue will be frame rail clearance.
Anyhow, thanks for the reply!
Cris
1 - 8 of 8 Posts
