I am selling a clutch pedal assembly out of a 1963 Galaxie that I modified to use a Fox Body Mustang clutch cable set up. The pedal box still bolts into the car using all of the stock mounting points and hardware. The firewall will require modification in order for a clutch cable to pass through. The aluminum clutch quadrant is included. The Galaxie brake pedal pad has been modified to utilize the Mustang pedal pad in order to match the Mustang clutch pedal. The clutch interlock switch has also been incorporated into the assembly to prevent the vehicle from being started before the clutch had been depressed. I ended up not using this due to going with a hydraulic clutch set up. I may still have a stock Mustang clutch cable and an aftermarket adjustable cable that would go with it if I still have them. I’m asking 350 for the assembly.
