I recently purchased Monroe 33053 shocks from a local NAPA store to replace the old Gabriel Stryder shocks (below). The Monroe shocks were a direct swap in the rear. But in the front the Monroe shocks do not have the same upper mount as the Gabriel - the Monroe is a straight threaded rod and one nut. The '64 Falcon shock tower requires two bolts, just like the Gabriel upper mount.
The guys at the NAPA store are no help, I called Monroe's support line and waited on hold for 20 minutes.
I could fab an adapter, but it seems like there ought to be a correct Monroe part out there. Does anybody know if any Monroe shock (or any brand) has an upper mount like the Gabriel shock?
Discussion Starter #2
Well a little more research answered my question; the Monroe 33053 will fit a Fairlane, but not a Falcon. I need a front shock for a '65 Mustang, like a KYB 343146 (below) or similar.
Maybe this info will help someone else.
1964 Falcon Futura 2dr
Pretty sure falcons only came with the straight shaft. Somebody probably added the mustang shocks+caps at some point.
You and J_van 64 are both right. Someone has changed the shock tower caps on your car to the Mustang type- they're interchangeable. Here's the Mustang vs. the '64 Falcon caps:
