I have this 289 block was thinking bout going stroker with it,but would it last a long time.I was also thinking bout putting a 289 standard crank in it maybe a steel crank have some rod bolts put in the rods and put a solid cam in it.I thought bout using some 69 351 windsor heads ported with roller tip rockers.I was thinking bout the victor jr. intake.The motor would have forged flat top pistons in it.What would be a good solid cam for this combo.The car will be a 65 mustang with a 4-speed with a 3:80 gear.Would this last longer then a stroker.I know you guys say that the main webs on the 302 isnt good for a stroker.I will be driving this car a lot what is everybopdys input.
