I finally got the crank to clear the oil pump with enough grinding. Now the pickup will not bolt on due to the windage tray being in the way. I called canton to ask for tech advice and they told me that the pan and windage tray need to be cut for clearances. Has anyone done this before to give me some advice on what I need to cut? 65 Mustang 408w, Canton front sump, Canton Main Stud Girdle, Canton windage tray, Canton pickup, Melling oil pump...
Thanks,
Shelby
