Im building a 392, with Comp Cams Hyd Roller XE282HR 232/[email protected],.565/.574, already have Edelbrock performer rpm heads but i am thinking that they mite be too small,should i buy another set Edlebrock Victor Jnr 7719$2800 Aus or should i buy AFR185s $3800 Aus or should i spend more money on the Perf. RPMs i have and do more port work on the axhaust,
please all and any advice is needed
Thats the same cam the ford uses in the 393W crate engine. It has dynoed at 450+ hp with 9.8-1 compression and out of the box GT40X heads. I say run the RPM's ported and run the max compression you can for the intended fuel. Hopefully that could be as high as 10.5-1 compression. Should be real close to 500 hp.
