Why cant i install a 65 merc 390 into a 62 ford galaxie.Steve Christ book states on page 28 that 63 up 3 bolt mms will fit into older 62 downgalaxies but the older 2 bolt mms wont fit into the newer63 upgalaxies.Napa swears ive got the right 65 galaxie mms. thanks mike
There ought to be dual mounting holes on each underside of the block. Just use the two hole 1962 era mounts bolted on to the applicable side of the newer engine. Can't use the newer three bolt mounts as you know already. I did what you are doing but that was twenty years ago.
Wm.
