Will 63-64 Galaxie FE motor mounts work in a 61 Starliner? THe Starliner motor mounts were the C-shaped version and rather tall. I am putting a 68 block in the car and would like to drop the engine a bit for more flexibility with intake choices.
No, frame mounts are different. And they are welded to the crossmember. Also you might have a oil pan to crossmember clearance problem if you lower the engine.
