Well, did such about fifteen years ago. We ran two #1 cables forward, tucked into corner formed by frame and underbody. Tried that one cable to frame biz but engine labored when cranking. The two cables made it crank over as normal. The ground went direct to engine block at the mount, the other went to relocated solinoid down near starter.
Biggest problem was rust in the trunk. As the battery charged, the fumes filled the trunk, causing the whole thing to eat away the paint and rust the remainder. Tried leaving the trunk lid open when not in use. Sold the car not long after this, so can't remember much else, other than used some Chevrolet truck mounting to hold in battery.
With lightweight batteries of today, do not see any advantage to this effort. For the cables going forward weighed as much as battery I seem to remember.
Wm.
