Right now I have my MSD ready to run in my 289 set with two blue advance springs and the base timing at 16 BTDC. The mechanical advance is set with the one that came with the distributor. I believe it is the blue which is 21*. Now MSD states that ''use as much initial advance without encountering starter load'' I can actually right now turn my initial past 20 degrees and have no starter load isuue. I am a little worried that this is the wrong direction...Maybe I should change the bushing to the next size which is the silver. It has a crank value of 25* Then I would have my initial down to compensate that. Any suggestions
Greg
Greg
