Hello,
We are a very new company with only a handful of customers so far. We came up with an ignition box that is much more compact than current offerings and has the ability to multi-spark to redline. The ignition box is suitable for any car with a distributor, either with points or Pertronix. It delivers longer duration AC capacitive discharge sparks. The design is unique in that it uncouples the power supply from the coil when firing, allowing for a more efficient and compact power supply. The result is less time between sparks, less heat generated, smaller size, using bigger capacitors, and multi-sparking to redline.
Miller Ignition High Energy Multi-Spark Ignition Boxes
Multi-Spark Capacitor Discharge Ignition. Convert classic cars with distributors to electronic ignition to boost performance and improve drivability. Built by hand in USA.
millerignition.com
