Just thought I would share, anyway my number 8 manifold bolt got stuck up in there and that has to one of the worst spots to break it. Anyway could not get nothing in there but 3/8 ratchet wrench, but problem I rounded the head of the bolt. So after beating the socket( don't know how cause it was tight area) on the bolt I went to turn and oops the head came of the bolt leaving nothing but a stud with about 6 threads on it.
So I searched and found the stud remover in the pic and it works, at first I tried it with 3/8 ratchet socket ( it works with 3/8 ratchet, impact gun or wrench) but oops again since the stud was in a lil crooked it cut it down to only 2 threads remaining. But it was advertised if you can grab it then it should be enough to remove it. So this time I grabbed it and tighten down with wrench and help of son holding in place and like that less than a 2 minutes it was out.
Also I purchased the MLS type gaskets and they seem to be doing the job.
Good find!
