1 - 20 of 31 Posts
I found my 66 stang has adjustable rockers on the 200 in it and i was wondering how normal a thing that was....
Also I have a Black block and this usually designates a '64/'65 model, does anyone know the engine paint color change over date?
My ID tag info is dated 05A, but my vin starts with 6... my production # is 00151, could this be the 151st 1966 mustang made?
What's y-all's take on this theory of mine?
Thanks!
FE
P.S. I will Have a damn FIT if nobody can answer my questions....
<font size=-1>[ This Message was edited by: FALCONAROUND on 8/22/06 1:39pm ]</font>
THis question and the same one on another site has remained unanswered for far too long. I take that to inderstand that nobody knows anything about the 1st gen Mustangs....
Thanks anyway.....
The little Bronco 200 I used for my ranchero had adjustable rockers.
Tracy
I guess I should go to a chebby site to ask my Q's.... This site has a horribly SMALL amount to offer this week...........
FE
If you car is 151 it is 151st car ORDERED for build. That is to say as the order came in it was assigned a VIN for build. Furthermore, was your car was built in San Jose? (R plant code) there is also a 151st car in Dearborn and Metuchen. The car was not necessarily the 151st built but I'll bet it was pretty near to it. It is highly likely that the motor is a leftover black one from '65. My '67 is 3904 from Dearborn and has a few left over C6# parts on it. It certainly is not odd for mid production changes as old parts get superseded by newer technology and practices. My early '67 had a washer bag and a center fill hole in the Diff, all things that got phased out mid '67 and I believe very late '67's got different steering columns and just to add to confusion the different plants would phase changes in at different times as their stock of old parts would run out and in fact often the different plants may use different parts throughout the entire run. ( Even in the 80's Taurus/Sables had different side mirrors depending on the plant it was built)
Not sure if it helps but I can't give you specifics by year date and plant etc.
You may want to find an MCA member that judges 65/66 cars as they will know all the nuts and bolts and finishes to a certain degree.
Stu
Discussion Starter · #10 ·
HA ha ha! Thanks Virg.
I'll get the whole tag info on here this afternoon!
FE
all the 170's and 200' I've had had adjustable rocker arms. Only one of them would have to be adjusted once a year or so because the adj. studs were worn and would turn in the rocker. I would adj. with the car running.
Discussion Starter · #12 ·
Thanks MC, I thought all the damn 200's were the bolt down type, but I be wrong! Here's my Door tag info!
6RO7T150151
65R/F/22/O5A/72/2/6
THat's what I got. Bone stock all original fomoco 200 black and red inline 6, original to the car....
Gary
Your car is actually the 50151st Mustang ordered. However they sold the millionth Mustang in '66 ( actually traded it to the owner of the first one) so it was still probably still early! Stu
Discussion Starter · #15 ·
This is why I thought I hat the 151's car made in 1966 at the " " plant.
Discussion Starter · #16 ·
OK, I found this!
Apparently mine is the 150 thousandth MUSTANG, but not the 150 thousandth 1966 Mustang! There is no way that anyone in the UNIVERSE can bake out 150K cars in 5 days...
So I am going to assume that the colors of my engine are correct and they will stay that way. Thanks for everyones help and assistance. Especially the two of you who actually said something....
Classic Mustang Decoder Results
Warranty Number: 6R07T150151
Year: 6 1966
Plant: R San Jose, CA
Body Series: 07 2 Door Hardtop
Engine: T 200 1v I6
Unit: 150151 150151
Miscellaneous Vehicle Data
Body: 65R code not found
Color: F Arcadian Blue
Trim: 22 Lt. Blue Crinkle Vinyl and Blue Rosette Vinyl, Standard Interior
Date: 05A January 05, 1966
D.S.O: 72 San Jose
Axle: 2 2.83:1, Conventional
Trans: 6 C4 Automatic
Discussion Starter · #17 ·
By the way I Ported my intake and exhaust bowls yesterday and port matched my exhaust to my head, which will give me about 5 HP overall! It's gotta man, I mean I couldn't put my index finger into the exhaust bowls or ports before and now I can fit my thumb
FE
No your car is the 50150th Mustang. All Fords have the number one at the beginning of the Consecutive build number. At the 100000th car the number 1 rolls over to a 2. BTW Mercury's start with 5's and Lincolns a 7
Stu
FE
You have to get the Offenhauser multi carb set up for it now
Stu
Discussion Starter · #20 ·
I seen one once.... Waaaaaay back in the day. Haven't heard of one for years... Looking for one for my Falcon right now.
The Mustang is a gift to my sister.
My car a '66 apparently came with a black and red engine.....
1 - 20 of 31 Posts
