It may cause a divorce but I am finally getting my 408 project under way and I can't wait till it all comes together.
Headers, carb, manifold, cam and lifters are all here. Still waiting on the rotating assembly, heads, and converter.
The final result will be 408 ci from a 1979 351w block .030 bored, typhoon manifold (similar to EDLBRK performer RPM, Holley 750 dp, Comp cams hydraulic cam 236-241 at .050 and 554-550 lift with 110 LS, ProComp heads or AFR 205, Crane roller rockers, Duraspark II ignition with MSD 6 box, Eagle forged crank, Eagle H-beams, Probe forged 19cc dished pistons, neutral flex plate and balancer, C4 with a 3500 stall converter and Transgo shift kit, Crites headers with 1 ¾ primary and 3.5” collectors, 3” exhaust through a set of Dynamax or Flowmaster mufflers.
I probably forgot a few things but that's because I'm excited.
