Are you serious? If so, there is probably an obvious answer to this question but what did you do to it? Simply heat the spring?
I would recommend buying some from Eaton Detroit, Coil Spring Spec. or Dearborn if you want good handling and good looks. How low are you wanting to go?
How low you're willing to go (and budget) will dictate more of how you should do it. I cut 1 coil from the fronts and swapped the rears with 97 Pontiac Montana mini van coils. It dropped the front about 3" and the rear about 2". I have had this setup on my car for at least 60k miles with no issues and it rides just as smooth as stock. I have also seen guys use springs from newer Police Interceptors that will lower your 66 by ~2" depending on your drivetrain/options.
