I have the same style pump on my '67. I never tried to rebuild it, I just picked up a remanufactured one at O'Reilly Auto Parts for $42.00. You just have to reuse your existing reservoir.
Yes, rebuilt all kind of vain pumps. If it's just leaking, a seal kit is around $10. You will need a puller to remove the pulley. If it isn't working then I would go with a rebuild.
Just put on a new Monroe shock absorbers to replace my worn out shocks and I’ve only done one and the car sits on the ground now
Monroe prt# 33049
It’s supposed to be the right one for the car and mounts correctly any ideas what’s wrong it sits lower now than with the old worn leaking air shock...
My NEW TO ME 1968 Galaxie 500 everything is a guessing game. So much work done, but. Not right work and hackery. Its a 390 car. Heavily cammed. Ya the times Ive watched torque and response turfed for rumble. So bumped diff from 2.73 to 3.70 that should help off line, but. I got it and near had...
I have a 62b build custom 500, it has a 545 cubic inch 871 blown fitech dual 1200hp power adder fuel injection system, c6 trans custom built with a 4000 stall, it has a cobra rear axle trac loc with a 456 gear, anything more than 3/8 throttle the tires go up in smoke so I bought a set of...
Hello,
I am brand new to this site but need your help. I have a family member with 1964 Galaxie R code he has had this car for 50 years. About 8 years ago it was completely restored and now he is ill and the car must go. My question is what do you think is the best venue to sell this car? Your...
