I do not want to remove or modify my gas tank. What is the best way to handle the fuel return line from the preasure regulator? Would it be okay to simply "T" it into the same line that the fuel pump uses to draw fuel from the tank?
Please help!
-Tom
I took my sending unit out, bought a pre-bent fuel injection fitting from autozone for 12.99 and took them both to a local radiator shop they soldered it for free only took em about 5 minutes. This is the only way I could find that would work I have had it this way for 8 months and it works perfect.
