I recently put this kit on my 65. I hooked up the hoses like this:
Front of prop valve, bottom - line to front brakes. T'd this single line into doubles at the original distribution block location (which required a new dist block with 3 points, rather than the factory 4 - although as Dan says, you could plug one of them up instead).
Front of prop valve, top - not needed the way I did it, but I couldn't find a plug. Ended up "blocking" it with the provided switch, which isn't required on a 65 as the actual switch is on the brake pedal itself.
Rear of prop valve - ditched the 1/4" fitting they gave me and used a similar one to take 3/16" line. But that went straight out to the rear brake line in the engine bay, using a horizontal union fitting.
Here's a pic of my booster/master which just about shows you the lines:
As Dan said, he's had issues with the pedal feel. My pedal feels excellent but I can't lock the brakes up. They pull up nicely, but lack that "emergency" feel, even after a few weeks of driving around daily. Pay close attention to the adjustable pushrod on the booster (which drives into the master) - get this length right! Oh, and I also had to use the shorter booster pushrod (also supplied in the kit) to get my pedal to line up... not sure if you'd need to do the same for the 64, though.
Overall I had a few niggles that I had to get around, but it's all working. Need to fine tune it now and get those brakes to lock.
