I've got the flywheel nuts off but, do the allen head looking bolts that go through the flywheel to the torque converter have to come out. If not, will the flywheel slip over them? Thanks
<font size=-1>[ This Message was edited by: Mayberry on 5/6/02 9:13am ]</font>
No they are attached to the torque converter. If you removed the nuts between the block and the flex plate then the converter is free to slide away from it.
They will slip through the flexplate.
If they have a hole in the center for an allen wrench you can prob remove them. Since they are allen head it's prob an aftermarket converter. Many of the aftermarket converter companies have gone to a removeable stud like that. The last two converters I have had were like that.
Later,
David Cole
