I can't seem to figure out why smoke keeps on coming out of my exhaust after the car is warm. I initially thought that water/coolant was getting into my cylinders (since the smoke seemed white in color) but the coolant level hasn't changed at all since i filled it up 2 months ago. HOWEVER, oil seems to be disappearing without any sort of leakage anywhere. I also noticed that my dist. coil has been leaking through the front (terminal) What should i be checking for? Would oil produce a light smoke? How fast (if at all) should oil be burning? Thanks for the help!
Programmer
You probably don't want to hear this, but your engine is probably slowly dying. My old 302 was so bad, I'd have to literally give it a quart of oil per gas tank fillup. Enough is enough, so I built a new engine. I've read that if you have to put a quart in per 1000 miles, its time for a rebuild. Smoke that is light blue in color is oil burning. If you don't have a lot of money, you could try replacing your valve seals, which can be the problem sometimes as well...
Chris
My '83 302 HO uses a quart of oil every
300 miles and DOESN'T SMOKE or leak!
I do find a lot of oil in the bottom of the
air cleaner housing though. It comes up the
valve cover breather pipe. I have another
motor almost ready for install though so
I'm not to concerned about it. I am
curious though about whats going on. The motor seems to have a lot of blowby after
its warmed up, more then the pcv system can
handle. There doesn't seem to be any blowby
when its cold, or maybe I just can't see it
because its clear??? Compression checks at
150 all the way around.
Bruce
