I have a friend who has a 4 door 54 ford with an auto tranny. It only goes into reverse. What kind of a tranny is this? Any suggestions on how I could go about fixing this (why will it only go into reverse, will it be hard to do myself or should I take it to a shop)? Any links to parts on the web or just getting a brand new tranny? Will a different tranny swap into it?
Thanks in advance.
Discussion Starter · #2 ·
Ok, here is generic theory question... what causes a tranny to not allow it to go into any gear except reverse. Are we talking dirty filters, bad fluid, messed up internals, all of the above?
I'd check the shift linkage first. If that's ok, it might be the linkage inside the trans itself, or a valvebody problem. Could also be clogged filter. Actually, it could be a million different things, but most likely you will have to pull the pan to locate it. I would do that anyway, if nothing else to just change the fluid (who knows when it was changed last)
Yeah, according to my freind it has not been serviced since last memory. It used to work and then just started to have problems after it sat for a year.
