Does anyone know a hub rotor that would work on a 78/79 f100 spindle would make it a 5 on 4 and a half bolt circle with stock caliper.
Hi
I"m kinda lost on your posting... you have a spindle for a 78]79 Ford. Car or truck?
and you want to put a rotor with 5 lug and 4.5 spacing is this correct?
best
It's a truck. Does someone make a rotor to go on the spindles to drop it down to a 4.5 so it can run a car wheel?
Can you get your hubs drilled for the desired bolt circle? See if you can cross reference the bearings and spindle specs between cars and trucks to see if a car hub/rotor will fit the truck spindle. You will also need correct offsets to have the caliper align, or use spacers if close, but maybe drilling the smaller circle would be easiest. IDK.
