Hey guys been a while...
Anyways I started to swap out the idler arm on a 65 Comet, the new arm was the arm only so I had to reuse the old bracket.
How tight do you tighten the arm to bracket nut? I got it pretty tight and the arm still rotates VERY easily by hand, am I correct in thinking it should be a good deal harder to swing the arm on the bracket?
Thanks Roadwarrior
