I've got a 65 with a 352 and COM car was idled way low when I got it. I set the timing and adjusted the fuel mixture because it was running really rich. Set the idle to about 900 rpm in park it ran fine drove it to work just so happens the starter went out that night got it back home changed the starter and a new battery made no adjustment to the Carb or idle now when I put it in gear it drops in real hard and stalls about ready to pull what hair I've got left any ideas
What method did you use to set your mixture?
If nothing up top was touched a S.W.A.G. would be vacuum leak. (accidental knocking the vacuum modulator line loose) ... 2C....
