Looks like im going rebuild my 75 302. But i need some help.
Heres what i know
Im going with a holley 600 carb 80457S
RPM Air Gap Intake
AFR 165's (So i can use the stock pistons)
Hooker Super Comp headers 6110
New bearings and rings
Melling standard Oil pump
2.5" exhaust with H-Pipe
Spintech mufflers
I need advise on Compression.
I have a felpro gasket kit, a tall 75 mexican block
What will my static compression be with 58cc AFR 165 heads and the stock pistons?
I need a Mechical Fuel pump recommendation and
I need a Timing Set recommendation?
Any help is appreciated.
tim
'75 Maverick 4-Door 302, C4
<font size=-1>[ This Message was edited by: tbirdz12 on 6/25/06 2:37am ]</font>
<font size=-1>[ This Message was edited by: tbirdz12 on 6/25/06 2:38am ]</font>
Need to know the cc's of the piston, head gasket thickness, how far the piston is in the hole etc. Once you know those figures use this http://sbftech.com/index.php/topic,93.0.html
copy and paste the above, as for the pump, carter makes a pump that will support you no problem. Run a cloyes true roller timing chain set.
http://www.sbftech.com
http://www.intaketrends.com
<font size=-1>[ This Message was edited by: woody1 on 6/25/06 2:54am ]</font>
Pistons measured at - 12 cc
and 0.028" in the hole.
Fel-pro 1011-1 are .041
with 58 cc heads thats 9.51 CR but with a .069" quench.
Would it be better to mill the deck to say go 0.10 in the hole and go with 62 cc heads which would be 9.48 CR with a .051 quench?
I dont want any valve/piston issues where i need to flycut or buy new pistons.
tim
