Greetings,
I recently removed the carburetor from my 1969 Galaxie 429. I foolishly failed to take pictures before removing it, and now I’m struggling to get the hoses routed correctly. This car has no A/C and a manual transmission. It does have power brakes. There is a heat tube that I believe connects to the choke directly from the intake manifold(?). There is a nipple on the front of the carb and a “t” fitting behind it. There is a tube that connects to the tube fitting. Does that also go to the intake manifold? I believe the nipple on the front connects to a hose that is attached to the distributor? Any help or advice would be welcome.
Thanks.
Thanks.
