I bought a fully balanced .030 302 from a reputable shop owner. He had the engine in his drag car for 2 seasons. My issue is that when I bought it I bought lower end only, I was informed that the pistons were a custom grind dome set up. I was also told that with the custom grind I would have to run aluminum heads to run premium pump gas. My question is, could I shim the head gaskets and run gt40p heads? Thanks for the input
