1 - 9 of 9 Posts
So I just bought a 65 Galaxie 500 convertible has original 352fe and cruise o matic auto. The trans is just not generating enough power for my liking and I was wondering what transmission would do the trick was thinking C6 but I just don't know enough and if so can the stock rear end handle the C6 any advice knowledge or suggestions would be greatly appreciated
why not just put some taller gears in the rear end ...
that will wake it up...
But will suffer if you do a lot of highway driving.....
you most likely have 3''00 gears and stepping up to 3"50 would help a lot..
I agree to the above. To add, a C6 will take more HP to run than a COM. The COM is a decent enough transmission for your current application.
I am no expert, but if you have a 9 inch rear end, it will handle most anything you are likely to throw at it.
that will wake it up... But will suffer if you do a lot of highway driving..... you most likely have 3''00 gears and stepping up to 3"50 would help a lot..
Hey Mr. R,
Are you sure that you meant to say this?
"Taller Gears" would serve to give better highway cruising, but acceleration off the line would suffer. Also, 3:50 to 1 is NOT "taller" than 3:00 to 1.
JC
Get a 700R4 trans. Good on low end and overdrive for the highway.
Should get turn key job for around 18 to $2,000.00 unless you can do it yourself.
3.06 1st gear, 1.63 2nd gear, 1.00 3rd gear, .070 4th gear.
Hey Mr. R,
JC
Your are correct Jc ....
But the numbers made it clear what I was thinking.. :D
1 - 9 of 9 Posts
