A new 3rd member will soon be mounted on the rear axle because of worn pinion bearings. But the flange (rear end 3rd member yoke) is a short one, approxymately 3inches, while the original is approximately 4 inches. Then the drive shaft has to be pulled one inch against the rear end. Is 1 inch too much movement or is the front yoke long enough. If the shorter flange is used, the snubber (guard shield) over the 3rd member joint, cant be used. This can maybe damage the rear 3rd member join when eventually hitting the body, or is the snubber unnecessary?
The alternative is to take the flange from the old 3rd member to the new. Is this difficult and needs much adjustments?
