Hi, I'd like to run this by you guys to see what you think.
1993 5.0 EFI - Trick Flow manifold, Cast Iron Dart heads, 10.5 TRW forged pistons. Total Seal piston rings, B303 cam. (Cams to small.... I know that now!)
Fired her up yesterday and started blowing tons of smoke! But it ran really well. Engine Vacuum 18 inches and steady as a rock. The smoke was so bad the neighbors came over to see if I'd burnt my garage down! Let the engine run for about 15 minutes. Still smoked. Removed PVC hose, still smoked. Remove spark plugs and everyone of them is wet and shows oil. Removed top of Trick flow manifold - dry. Remove lower manifold - it APPEARS that the intake manifold gasket DID sealed. Gaskets dry. Each intake port was wet, the entire port - top to bottom.
I had torqued the manifold bolts to around 15 pounds. When I pulled the top end down it seemed they were NOT tight enough. I used those soft metal bolts that came with the dress up kit. When I put the gaskets on - I used very little sealer around the ports. Didn't want the sealer to get into the ports.
So here is what I think and would like your opinions, the intake manifold gaskets were leaking. I should have used more sealers and grade A steel bolts and torqued to a higher amount.
Am I reading this right? Or can you guys think of another reason for the SUPER heavy smoking. When I say super heavy smoking - could NOT see into the garage when revd to around 3000 rpm! - Even if I forgot to put the oil rings on the pistons I could not believe it would have smoked this much.
Thanks for your help!
Mark
Mark
