1 - 9 of 9 Posts
Ok, i just got my 165 AFR's in, trying to figure out what is the best route w/ the head bolts. The AFR's are 1/2" drilled. My 289 has 7/16 bolts. I found a set up ARP 7/16 bolts and some APR step washers for about $80 total. Or would it be better to get these bolts that have the widened head area. Not sure what to do..
http://store.summitracing.com/partdetail.asp?part=ARP%2D254%2D3708&N=700+115&autoview=sku
'65 2+2 TimeMachine: 289 4v 4sp 14.44 @97.29
1991 Honda Civic Si- daily driver
2002 Midnight Edition Ford Escape
<font size=-1>[ This Message was edited by: ga289stocker on 8/29/06 7:10am ]</font>
I went with the ARP bolts that have the wider head area. Seemed to me it was a better option than the step washers. I put the Windsor Jr. heads on my 289, not at all a strip car but it has been 2 years since the head work and no problems yet.
On 2006-08-28 14:49, woody1 wrote:
those will not work, use the inserts
Woody, can you explain the problem w/ those bolts. I don't have a problem using the inserts , it just seemed like it might work better them..
oops, i just saw your note, your just to fast for me. thanks. So I could use those widened head bolts and be fine?
let me look at those again real quick, I cant tell if they are 1/2 inch widened at the neck.
I used the 7/16 with stepped washers on my 289 w/ Windsor Jr. heads, no problems after driving it fairly regularly for 3yrs.
I like ARP 7/16" undercut studs with the step washers.
1 - 9 of 9 Posts
