Finally got my 302 running, and it runs great! Just one thing, there is a small oil leak at the rear of the driver side cylinder head. The oil seeps out very slowly while the engine is running, not under any pressure. I have 30psi at idle hot with straight 30W oil in it, and 55 or so around 2000 rpm. The pressure rises and falls as rpms go up and down.
I am using the Edelbrock RPM heads, RPM manifold, and the block was square decked flat. Head gaskets are Mr. Gasket 5807 Ultraseals.
I can run the engine for 10 minutes, up to temperature, then shut it off and there would be a few drips worth on the little casting ledge on the block just under the lower rear head bolt. I realized that it leaked yesterday when I prelubed it, but just figured I spilled some oil out of the valve cover area.
What could be causing the leak? I checked to make sure the drain back hole wasn't the cause: I cleaned the area well then poured 1/2 quart of oil down the drain back hole and waited for it to seep out down along the back of the block. I got nothing. I retorqued the heads to 63 ft. lbs as per ARP's instructions. The car ran fine, the oil is clean, and it held coolant. I used ARP sealer on the lower head bolts that go into the water. The leak is enough to need to fix it.
I can't think of anywhere in the head gasket that holds oil, except for the drain holes, and they are not under pressure. They are also complete circles enclosed between the head and block. Could the little plug at the top of the block in the back be leaking, then running down the inside of the manifold, to the left side, then out the bottom? The right side head is totally dry and has no leak. I used the cork gaskets at the intake rear and front, but dimpled the manifold and block to hold the contact cement. The gaskets are dry.
Any ideas?
Any ideas?
