I was replacing the front shocks in my '66.....which took longer than expected. One done I went to move the car and no brakes. I must have hit the main line coming off of the master cylinder. Upon inspection it was in rough shape so I am thankful it happened in my driveway and not on the road! Now the stupid question. How is the hose connected on the junction block? The master cylinder side is threaded and came right off but I can't get it off of the junction block. Is it a special fitting requiring a special tool? It is corroded so I cannot get a clear look at it. I am looking for a replacement on line but everything shows a compression fitting instead of a standard threaded fitting. Any insight to help me would be really appreciated!
It's the original drum brake system with a single master cylinder.
