Okay then... in another way around.
What was the fuel flow rate (jet size) on the fuel side and the n2o rate (jet size) for the system you had, and its power rating.
ie 150shot = number 'x' fuel jets @ 'x' PSI pressure and number 'y' n2o jets at 'y' PSI line pressure?
Is that able to be quantified?
I am trying to set up a propane/n2o system ony. No fuel.
It is very simple to deliver liquid propane into the inlet and similarly easy to add n2o.
I just want to try to quantify how much propane to start with (GPH type numbers) to achieve the equivalent of a 150 shot system.
If I can find the fuel delivery amount for a 150 shot I have a start point as propane is about 87% of the BTU level of 91 octane fuel.
