Initial expense of a blower is 3-5 times that of nitrous, and you can buy a lot of nitrous for the difference in cost. With a blower you have the extra power whenever you need it. Sometimes a bottle will run out when you don't expect it, then you have to go get it filled. A blower motor will usually run warmer so you have to plan for that with upgraded cooling. Pros and cons to each method.
