Wtf?
new gas tank,
new sending unit
new mech pump. (airtex, autozone brand non filter)
still NO gas to carb.
i siphoned the gas up the fuel line to the pump. plenty of gas spilled out. i reattached the fuel line to the pump and cranked the engine. no gas in the bowl...the bowl is still empty. i checked the float level and set it to carb rebuild kit specifications.
i added gas in the bowl. the engine started, it only ran with gas in the bowl.
i attached a second rubber hose from the pump to the tank. cranked the engine and still nothing goes into the bowl.
i disconnected the fuel line going from the pump to the carb and placed it in a small container and cranked the engine. nothing came out.
im thinking
-my cam eccentric is to blame....
-the mech pump from autozone died on me....
-the hose from the pump to the carb has a pin hole leak
-the fuel filter attached to the carb is completely clogged, again...
guys, could it be anything else ???
