More accurtely not much good a diagnosis. Once I am sure what to do I generally can do it. I think (actually fear) I have a starter problem. Battery is solid and everything seems to work....except for starting. When I turn the key, I can hear the solenoid click but the starter does nothing. Have the original long tube headers. it is tight down there. While just perusing this site and archives in the past I see I will have a major project to get that starter out which is why I said "fear". Just want to be sure it is the starter and not the solenoid. After I did a couple of turns of the key, I did notice the wire to the starter was warm. That would seem to tell me power is going there. Anything I can do to check the solenoid? Any help apprecaited. Thanks in advance.
I should add that I tried tapping the starter a bit to see if I could shake it loose assuming that might help............but it didn't.
