I know some of you guys have built SBC's before, so hopefully someone can give me a quick answer. I'm rebuilding a 2.8 V6 for an S10 Blazer (to make some cash on for my Mustang - see it's semi Ford related!
), and I need to know if there should be a gasket for the oil pump.
The oil pump bolts to the rear main cap (which is the same setup as a SBC if I remember correctly), but I can't remember if there should be a gasket there. If there shouldn't be, should I use some silicone at all, or just leave it bare? Thanks in advance!!!
-Brian
-Brian
