My 1939 Ford Coupe has a 351W - stock 69 4v rebuild, RPM Perf. Intake, Edlebrock 600 carb, mild RV type cam and has about 60,000 miles on it. It was rebuilt 17 years ago with stock rail rocker heads and cup type valve stem seals.
It does the oil buff after it is cut off and restrated 10-20 min later. Overall the engine runs good. I bought a good quality compression gage tester but have not performed the test yet.
I would like to diagnose the engine and determine: (1) do I need a rebuilt. (2) or just replace valve stem seals to correct. (3) of possible install new better aftermarket heads such as AFR or Edlebrock.
What is the best diagnostic procedure?
