Hi all, I have read a lot of threads on cooling. I have a 302 with an aluminum radiator and I run between 180 and 190 as long as I have a regular flow of air into the grill. One run through a cruise and I am headed north of 220 in a hurry. I think I will stick with the flex fan and shroud, although I may consider a larger radiator.
Does anyone have an oil cooler and have you found that to work? can I offset the oil cooler closer to one of the headlights? I have AC also and running out of room in the center of the grill.
I am interested in doing this but not if it will net me no change....
Thanks,
Mike
302, aluminum heads, roller rockers, 65 Falcon Ranchero
Thanks,
Mike
