Programmer
I'm building up a 351w engine and since it is going in my '66 stang, it will have to have a front sump oil pan. Should I install a baffle in it so the oil stays up front more, when i'm going down the track?
Chris
Chris,
If this helps, I have a boss 302 windage tray in the 302 in my '70 Maverick and have
so far not had any problems with pressure loss at the track. Milodon has a front sump pan with a baffle already in it and it looks like a stock pan from the outside.
I also have a windage tray + baffled pan in my '70 Torino 429scj and likewise have never had a pressure loss. A friend, however
has no baffles / tray in his 460 Torino and is always losing pressure under hard acceleration.
Perhaps you could use both for an extra
measure of insurance? Sure couldn't hurt!
Programmer
Thank you guys. That was a good read, too, 89 coupe. I now know i will not be using a stock pan...
Chris
I bought the FMR front sump pan and welded my own baffles in it. Baffles that require a little jimmying when installing around the pickup, but will force enough oil to stay around the pump to avoid cavitation. Even at 1.5-2 G's. If I had known about the front sump stock depth baffled oil pan before I did this, I might have forked over the extra $100 to get it premade. Or not.
