Ok, here's what I got: new Autometer oil pressure gauge and sending unit. I was suspecting my stock guage and sender was old and not reading well.
351w stroker with only 10k miles, Melling HV pump. 5w-30w Mobil 1 sysnth. oil
What it read: cold-25psi idle to 50psi above 1000rpm.
full operating temp-10/11 psi at idle to 50 psi above 1000rpm
I've heard anything below 35psi at idle is bad to anything near 7psi is bad. Should I be concerned? Runs great otherwise. No oil burning.
I've noticed that the oil pick up is kind of far from the bottom of the oil pan maybe 3/8" to 1/2" including the gasket thickness. Should I try to bring the pick up closer?
Thanks.
Thanks.
