It seems a bit to me.Camshaft distributor gear may show advanced wear and or oil pump shaft service may suffer.I too have seen FE's with windage trays and hi-volume pumps seem to cause pressure problems due to drain back problems when drain back maintence is not performed.Is your oil pump modified?What weight oil?Just a few items that come to mind.I noticed you restricted the rocker oiling,on a "street" driven engine will the exhaust rockers not suffer?
<font size=-1>[ This Message was edited by: Livermore Dave on 2/25/02 11:08am ]</font>
