I'm losing my mind here.
I've got a 260 in my Falcon that I rebuilt and was running fine for about 500 miles, then it started losing oil pressure intermittently over a 10 minute period. It sat for a couple months because I didn't have time to tear into it.
Finally pulled the pan tonight and the oil pump pick up tube was loose. Seemed like an obvious smoking gun for the symptoms I had.
I checked the bearings and they looked fine, so tightened everything up and filled it back with oil.
Didn't prime running off the starter with plugs out, so switched to a drill down the dizzy hole.
It spins but never loads up. Pulled the filter and that pump is pumping zero oil.
I'm trying to avoid pulling the pan again, so I tried backfilling it via the output hole at the oil filter. I ran the pump backwards and forwards. No dice.
I read a last ditch trick is to fill the pan stupidly high with oil so the pump doesn't have to lift as much vertically (then drain it down after priming). No dice.
When I run the drill in any of these tries it never loads up at all. So either the drive shaft isnt turning the pump (it was before), or the pump gears are just shot?
Anything else to try before dropping the pan and taking a bunch of stuff apart?
