1 - 12 of 12 Posts
I was wondering if anyone has wired up a late model alternator in an early mustang?
I want to use the newer style serpentine belt system, alternator brackets and alternator from an '88 lincoln 5.0 HO in my '66 mustang. I'm unsure how to do this because I believe the late model has an internal regulator.
I've read the article in FM on the powermaster alternator and might be forced to go that route; however, I would like to reuse the alternator from the Lincoln right now.
Thanks for any help.
Which alternator - if it's the one with the rectangular plug in the side with two black feed wires coming out ("IC" type they call it IIRC), it is a 5 wire hookup but I don't have access to a diagram here. The green/red goes to the existing green/red, the black wires to the battery and I forget where the other two go. The later 3G model is an easy 3 wire hookup. If you have the IC type, replace the connector with a new one as it's prone to FIRE. The rebuild models should come with a new connector in the box. Ford had a big problem with these in the mid 80's. Stupid idea for an alternator hookup.
Note to FM - can you stop blocking Network54 items? That's still...unsmart.
<font size=-1>[ This Message was edited by: ckelly on 11/21/06 5:29am ]</font>
<font size=-1>[ This Message was edited by: ckelly on 11/21/06 5:34am ]</font>
The alternator has 3 wire connectors; however, it has the rectangular plug on the top. Also, how can I tell if it has an internal regulator? Myalternator looks different then the picture that is shown. Is the regulator bolted to the back of the alternator or is in inside?
An 88 Lincoln will have a 2G alternator. The regulator will be bolted on it with the commutator brushes attached to it. It will have similar connections as the 3G shown above ( at least functionwise) so it can be used also. Stu
That is what concerns me because my alternator does not have anything bolted on it and I pulled it from a 88 lincoln Mark VII LSC.
If it doesn't have the regulator on it it may be an optional 100 Amp unit. Stu
Sounds like the optional external regulator version. I don't have the wirng diagram for it. The 3G would be a better choice for an upgrade otherwise you may as well just do a good rebuilt stock alternator.
Ford 1G and 2G alts both have poor low rpm charging issues that the 3G addresses. Stu
Discussion Starter · #11 ·
I think I will upgrade to a 3G but for now I am going to use the stock Lincoln alternator. I guess since it does have an external regulator I can use the existing wire harness, right?
Without a wiring diagram for the Lincoln I could not say for sure but the connections should be the same for the Field, Stator and the Battery. So double check. Stu
1 - 12 of 12 Posts
