Hi everyone,
I bought the 1968 Mercury Montego from a dealer. The backstory on the car was this...the father/previous owner of the car had died, the son had either sold it to him or traded it in on something. He said the car had sat around for a few years, then in the 90's the father had "hot-rodded" it, whatever that means, drove it around for a while, but had a minor wreck and the car sat around for 15 years or so, until it was sold to him, then to me.
The engine never leaked a drop of oil in the several years that its been in my garage, but now today, with the engine out of the car, I'm de-greasing it, wire-wheeling the rust off of it, and I flip it over to remove the oil pan and this is what I find. See pictures...
First, the oil pump is a Melling M57HV. This is a high volume pump, according to my research, this can be a problem if other steps weren't taken during a build. However, I'm not sure what these steps are, something about plugging one or more oil galley holes, but I wouldn't know where to look to verify this was done properly. Should I just assume this engine was rebuilt, and done right? The car drove, and shifted fine, and would idle and not overheat, was sending oil up top, and the longest test was about 20 minutes with no problems.
Next thing that caught my eye was this OFF COLOR piston rod. The other 7 are all the same, two different colors, but this one is all orange-ish, what do I make of this?
Third, this is how the oil pan looks after being wiped down. There was some sludge in the bottom, but nothing metal, no shavings, does the location of the black areas mean anything?
Fourth, see that big dent, I'm pretty sure that was part of the "accident": that retired the car or the dad as the driver of the car. Should I try and pound that out, leave it, buy a new pan, what?
Fifth, the old pan gasket was cork, with a LOT of silicon helping out. What are the best value gaskets for not dripping...cork, Fel-pro synthetic, some brand new technology?
Also, I found spring shims too, see thread here, if this makes a difference... Questions about 390 spring shims.
Thank you for reading this far and for any helpful advice you might offer.
