Like the title says, I'm looking to replace my worn out radiator core support mounts. There's no source for an exact replacement that I've found, but I'm hoping someone on here has sourced an alternative part that works.
Let me know and thanks in advance!
Try this
Where are you located?
I'm near Nashville. I've found some Bronco supports that look like they might fit. I ended up having to cut out the frame around the original mount points - it was too far gone. I'm in the process of welding up new metal now. I'll give George a call and see what he's got. If that doesn't work out, I think these Bronco mounts I have can be adapted to work, especially since I'll have to drill new holes anyway.
Thanks for the replies!
