OK we put in a 302 in my 78 Ghia coupe. Runs great while going down the road...about 190-200 degrees, but when I'm idling for a few mins temp starts to go up. I changed the waterpump and thermo. Also I have headman headers on...was thinking about getting the hookers that have the coating...would that Make a difference? The rad is part 514 and 3 core using the mechanical fan. Not sure what kinda of aftermarket electric fan would fit or take care of the problem. Please help. This is not a stock 302...was just gonna put the reg manifolds back on if all else fails. Maybe I can find something at Carlisle this week end. I usually run my car in the parade on Memorial day and today it over heated and I had to retire to a safe spot early....any advice and help is greatful...thanks!!
YO STEVE
Is your radiator used? If so, maybe it needs to be cleaned out, pluged cores will kill the cooling at low rpm.
Went to Carlisle and got a smaller water pump pulley and it solved it. drove home 2 1/2 hrs and it ran 190 or less degrees and hit traffic on the way back and didn't go over 190...thanks all!!
Turning it faster.......
